1. walterneedshelp's Avatar
    hello , please help, i cant get rid of a popup saying (se for android is disabled,please tap here) , i got a samsung galaxy prime, and when i long press this notification for app info, its directing me to "knox notification manager' if you force stop it,it keeps popping and popping again, please help me its really annoying T_T
    08-12-2015 11:51 PM
  2. Nikolay M's Avatar
    Hi, I have been reading a lot of stuff about this problem and the only solution for me was to get root access with the app "Kingo ROOT", then to install "Titanium BackUp Pro" and to freeze all Knox apps.
    You can try, it works for me
    11-13-2015 04:04 AM
  3. 9944949577D's Avatar
    My mobile samsung galaxy showing me again and again Se for Android has been off. tap here for more information so please provide me solution of this problem so i can stop this pop up massage
    06-12-2016 12:59 PM
  1. Replies: 26
    Last Post: 08-28-2015, 02:55 PM
  2. How do I stop my text messages from going to draft message?
    Last Post: 08-13-2015, 08:39 AM
  3. Replies: 1
    Last Post: 08-13-2015, 01:58 AM
  4. Replies: 0
    Last Post: 08-12-2015, 11:49 PM
