1. AC Question's Avatar
    Hi, I am a note 2 user since 2 years. Now I want to upgrade my phone. What should I buy S6 or Note 4 ?
    Please help.
    08-13-2015 02:19 AM
  2. the tall guy's Avatar
    Please help.
    It depends on what is necessary to you. If you want removable storage and battery and the Spen go with the Note 4. Might be worth while waiting to see what the Note 5 brings to the table.
    08-13-2015 03:36 AM
  3. nahoku's Avatar
    I expressly bought the Note 4 for the S-Pen. I looked at the S6, but passed on it. Haven't regretted it.
    08-13-2015 03:48 AM
  4. the tall guy's Avatar
    Love your State btw I'm from the UK, been to Hawaii twice - one day when I'm old and grey I want to retire there.
    nahoku likes this.
    08-13-2015 04:25 AM
  5. nahoku's Avatar
    Yes, Hawaii is very nice, but very expensive. Born and raised in Hawaii and now retired myself. You're very welcome to retire here too! Aloha and thank you for you kind comment!
    the tall guy likes this.
    08-13-2015 06:21 AM
  6. the tall guy's Avatar
    Mahalo
    nahoku likes this.
    08-13-2015 07:06 AM
  1. Are you happy with your S6 Edge?
    By TurkXtreme in forum Samsung Galaxy S6 edge
    Last Post: 08-28-2015, 02:24 PM
  2. Replies: 0
    Last Post: 08-13-2015, 01:48 AM
  3. S6 Bluetooth connections
    By Judgeatc in forum Ask a Question
    Last Post: 08-13-2015, 01:26 AM
  4. Replies: 0
    Last Post: 08-13-2015, 01:22 AM
