A
AC Question
Why my phone screen stopped working after removing from charging
Hey Guys,
So i am using huawei honor 3c...the problem i m getting is that the screen stops responding after i remove from charging ...it starts working again when i plug the data cable again into my phone .... the power button is working perfectly it on the phone but the phone touch in not working i have to then remove the battery and put it back start the phone and its working again ..
So can u guys tell me what the problem in my phone causing this or any solution or tip that might be helpful .. i m using android version 4.2.2 that was installed by huawei.... w8ing for reply
Note : Sorry for my bad english...
Hey Guys,
