1. AC Question's Avatar
    Brand new out of the box. I plugged it in to charge and I'm getting a flashing read question mark in the battery icon.
    08-18-2015 05:53 PM
  2. Mooncatt's Avatar
    This is a very active site, so it's not uncommon for a thread to be buried quickly. I don't even recall seeing the original posting.
    I haven't personally had this question mark issue, but I'd check the battery and connections. If it's a brand new phone, then see if you can take it to the store and swap the battery with another phone and see if you have the same problem. It sounds like the phone isn't recognizing the battery, or perhaps thinks the battery is defective and unable to accept a charge.
    B. Diddy likes this.
    11-27-2015 11:06 PM
  3. Golfdriver97's Avatar
    It may also be a faulty wall charger or cable.
    11-28-2015 02:42 PM
  1. Are we going to get the 5.1.1 update?
    By EricandSuebee in forum Motorola Droid Turbo
    Last Post: 08-20-2015, 10:20 PM
  2. Question about S6.
    By GabGurl39 in forum Samsung Galaxy S6
    Last Post: 08-18-2015, 05:45 PM
  3. Silly question about s6 calendar
    Last Post: 08-18-2015, 05:19 PM
  4. Replies: 0
    Last Post: 08-18-2015, 04:48 PM
  5. Why doesn't my Lexus GPS work when I put USB drive for music?
    Last Post: 08-18-2015, 04:44 PM
