1. AC Question's Avatar
    when on speaker they can hear but not when speaker is off
    08-18-2015 11:17 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone exactly? 4G LTE just refers to the network type. Can others hear you when you're using a wired or wireless headset? Chances are your phone mic is either blocked or has failed. Check the mic opening and make sure it isn't blocked by any debris (like lint).
    08-18-2015 11:57 PM
  1. Replies: 7
    Last Post: 08-20-2015, 11:19 PM
  2. When changed my sd cad on samsung galaxy s6 wont turn in nie
    By Jamesy boy7 in forum Ask a Question
    Last Post: 08-19-2015, 12:31 AM
  3. Is the VPN the same as an APN on a Droid Maxx?
    By AC Question in forum Motorola Droid MAXX
    Last Post: 08-19-2015, 12:28 AM
  4. Replies: 2
    Last Post: 08-19-2015, 12:23 AM
  5. My Samsung smart switch doesn't work! Why not?
    Last Post: 08-18-2015, 10:12 PM
