Problem with phone.
That is about 6 months i am fighting with this problem. My phone mystical overheats and shouts down, sometimes with loud noises and strange things showing on my screen. Then if it's hot and i turn up it it hapends again, but if i cool my phone for a while and then turn up. There is no problem. I am playing minecraft and farming sim 14 on android phones and if i play +2 minutes then it overheats and turns off. I am using Gigabyte Gsmart Arty A3 rooted about a week ago. Please help me that issue is even if i do simple things like calling, watching videos and simply surfing web(Twitter, Facebook, my interest forums)
Re: Problem with phone.
Hi,
Have you contacted the supplier, maybe you have a damaged phone? if it's still under warranty then they should be able to fix / repair the device? also bare in mind this phone comes with 1gb of ram. Some apps like Minecraft and Sims are big hefty apps that take up a lot of resources.
