1. AC Question's Avatar
    The dots on my lock screen aren't appearing for me to put in my pattern! I can't unlock it at all. It still has the time, emergency call button and the notification bar but no pattern input! This has never happened before. I tried rebooting the phone, taking out the battery, and even hardware factory resetting it. NOTHING is working. Even after factory resetting it (using the hardware keys), the default "slide to unlock" isn't even showing up! I tried sliding where the bar usually is, thinking it might have been a glitch or something, but nothing happened. I have a Motorola Droid 2 and have never had any problems with it (except, of course with it being such an old device with very low RAM, problems with performance). I really need an answer as I use my phone everyday constantly for work. PLEASE HELP ME ASAP!!!!
    08-19-2015 09:08 PM
  2. gevertex's Avatar
    Can you post a picture of your phone's screen? It might help in diagnosing the issue
    08-19-2015 09:31 PM
  1. screen off notepad
    By fragologist in forum Samsung Galaxy Note 4
    Last Post: 08-23-2015, 08:56 AM
  2. Replies: 5
    Last Post: 08-22-2015, 12:01 AM
  3. Screen On Time (SOT)
    By TeeAnn in forum Samsung Galaxy S6
    Last Post: 08-20-2015, 07:38 AM
  4. I soft bricked my phone, can I please get some help?
    Last Post: 08-19-2015, 10:33 PM
  5. Replies: 5
    Last Post: 08-19-2015, 08:56 PM
