1. monizzle's Avatar
    i debated if i should ask this question here or not but i figured someone out there must have encountered this dilemma. . .
    so i want to upgrade my phone to the g2. i currently have the moto cliq and it's driving me nuts. my boyfriend and i are on the same plan. he is long overdue for an upgrade but i am not. if i upgrade my phone to the g2, i would be paying 3x as much as he would if he were upgrading to it. my question is, if he "upgrades" his phone to the g2 but then i put my sim card in it, will it work? i here conflicting stories that you need to use the sim card that comes with the phone in order for it to work properly. is there a way to get around this?
    01-28-2011 06:01 PM
  2. Cyber Warrior's Avatar
    I have 4 lines on a family plan and never have a problem using someone else's upgrade. Just tell the rep you would like to use the other lines upgrade for your line.
    monizzle likes this.
    01-28-2011 06:08 PM
  3. monizzle's Avatar
    turns out it was super easy using his upgrade. i am now the proud owner of a G2.
    01-31-2011 05:28 PM
  4. takeshi's Avatar
    You already know this if you're using the G2 but that is not correct. If the device was bound to a specific SIM it would defeat the purpose of the SIM. That said, network/subsidy locks aren't uncommon in the US to prevent the use of the phone with another carrier's SIM.
    02-01-2011 09:10 AM
Tags for this Thread
