1. AC Question's Avatar
    android version 4.4.2 cricket , lg70 optimus, how do you switch to 3g. ? no menu w/cdma etc. many of apps disabled..which do i need on? if any..thx!
    08-20-2015 04:40 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Switch to 3G from what? Are you getting any data reception at all? Are you stuck on 1X or EDGE, or are you trying to prevent it from connecting to 4G?
    08-20-2015 12:57 PM
  1. Replies: 6
    Last Post: 08-22-2015, 07:11 AM
  2. Replies: 3
    Last Post: 08-21-2015, 12:43 AM
  3. Replies: 1
    Last Post: 08-20-2015, 01:00 PM
  4. Switch Off Interruption Notifications?
    Last Post: 08-20-2015, 12:58 PM
  5. I upgrade to Win 10 Pro - Note 10.1 N8000 (2012-2013) Not found, what?
    Last Post: 08-20-2015, 06:51 AM
