max size of internal memory is too low 1.12 GB instead of 4 GB in Nokia XL?
hi, My smartphone model is Nokia XL Dual SIM, Software Version 1.2.3.2, Nokia X Software Platform 1.2. I am facing the issue that is maximum low internal memory is 1.12 gb only. But Before buying the product or before installing all android apps into my smartphone, I have 4 GB internal memory(maximum allowed size). But after installed apps, the size is 1.12 GB(maximum allowed size). I have cleared cache, junk files everything. All are fine. but it shows 1.12 GB (max allowed size). I am suffering to install new apps because minimum free space is 43 MB only. Where the remaining 2.7+ GB gone in the internal memory? Please help me to get back to previous allowed size 4 GB. What are the steps required to achieve it?
