1. jmohan1984's Avatar
    hi, My smartphone model is Nokia XL Dual SIM, Software Version 1.2.3.2, Nokia X Software Platform 1.2. I am facing the issue that is maximum low internal memory is 1.12 gb only. But Before buying the product or before installing all android apps into my smartphone, I have 4 GB internal memory(maximum allowed size). But after installed apps, the size is 1.12 GB(maximum allowed size). I have cleared cache, junk files everything. All are fine. but it shows 1.12 GB (max allowed size). I am suffering to install new apps because minimum free space is 43 MB only. Where the remaining 2.7+ GB gone in the internal memory? Please help me to get back to previous allowed size 4 GB. What are the steps required to achieve it?
    08-20-2015 06:01 AM
  2. Mooncatt's Avatar
    That 4 GB internal storage is the total amount, which is shared between apps you download, the Android operating system, and other miscellaneous files. The OS is most likely the biggest culprit here, which there's nothing you can do about.
    B. Diddy likes this.
    08-20-2015 11:34 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Mooncatt is correct. See this guide for tips on how to maximize what little storage you have: http://forums.androidcentral.com/amb...-warnings.html
    08-20-2015 12:52 PM
  1. Duplicate numbers in dialer
    By Vintila Cristian in forum Samsung Galaxy S6
    Last Post: 12-03-2015, 01:03 AM
  2. Is it now safe to update to Lollipop?
    By JustinianVI in forum HTC One M7
    Last Post: 08-28-2015, 04:53 AM
  3. Is buying a used M8 my best option?
    Last Post: 08-22-2015, 04:08 AM
  4. Replies: 2
    Last Post: 08-20-2015, 01:10 PM
  5. Replies: 1
    Last Post: 08-20-2015, 03:32 AM
