1. Sarah Gough's Avatar
    Im currently on gingerbread and most apps either dont or stop working. I wanna downgrade to the ice cream
    There hasnt been any update for almost a yr so it hadly gonna make much diff.
    08-20-2015 06:01 AM
  2. dirk de boer's Avatar
    By flashing the old firmware, tell us your model/manufacturer name so that we can help you further
    Verstuurd vanaf mijn KK STOCK V3 met Tapatalk
    08-20-2015 06:40 AM
  3. Mooncatt's Avatar
    Every phone is different, and some may not even be able to downgrade. So you'll need to find directions and info related to your specific device. Also, it's not something you're supposed to be able to do according to the manufactures. Any info you find will be dependent on other users that have experimented with what can be done. If it's not a very popular device, it's likely no one has figured out a reliable way to downgrade.
    08-20-2015 11:31 AM
  1. Can't find how to switch to 3g?
    Last Post: 08-20-2015, 12:57 PM
  2. Switching from the iPhone to Note 4, what can I expect?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 08-20-2015, 08:06 AM
  3. How do I disable assisted dial on my Samsung S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 08-20-2015, 07:47 AM
  4. How to root my android phone?
    By John_Kery in forum General Help and How To
    Last Post: 08-20-2015, 06:41 AM
  5. Is there a camera app to support the earphone socket on selfie remote?
    Last Post: 08-20-2015, 06:35 AM
