1. WCL49's Avatar
    There is an Eye in a box in the top right corner of my phone and when the screen goes to sleep the icon appears for just a moment then leaves.
    08-21-2015 06:32 AM
  2. belodion's Avatar
    Welcome to Android Central.
    That could indicate that you have the phone set to keep the display on as long as it detects your face. Check in Accessibility.
    08-21-2015 06:40 AM
  3. WCL49's Avatar
    Thank you belodion you've been a BIG help!!!!!!! (Thanks)
    belodion likes this.
    08-21-2015 06:49 AM
  1. Why does my wifi turn itself off on my Samsung S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-21-2015, 06:29 AM
  2. why does my wifi turn of on my s 5
    Last Post: 08-21-2015, 06:26 AM
  3. why does my wifi turn of on my s 5
    Last Post: 08-21-2015, 06:24 AM
  4. incoming voicemail does not answer , phone just keeps ringing
    Last Post: 08-21-2015, 06:23 AM
  5. why does my wifi turn of on my s 5
    Last Post: 08-21-2015, 06:21 AM
