If your battery is drained by a power bank, what should you do?
  • Start date Start date
A
AC Question
if your battery is drained by a power bank, what should you do
the battery is not the phones battery. its another phones battery and recently, i connected it to a power bank it rather drained my battery
I had the same problem. I did a search. I found that the USB cable that comes with the Bank is of poor quality. I had an Original Samsung USB cable and connected it with the Power Bank. Bang it works now it charges the phone.
Change your cable to a thick one not the the thin type and you will be ok. Glad to help. I hope this will help you
godef
