1. sebadnox's Avatar
    Hello there, im asking for help to pick a new smartphone to replace my old Sony Xperia Active, and i am unsure about the quality of the camera of smartphones that i have looked to. I have to say that the key features that i´m looking for my future smartphone, are mainly a good camera and a good battery life. Being more specifically, i´m specially expecting the camera of my smartphone to be good on low light, on movement, on macro mode, and of course, to have good definition on photos. On my economic possibilities, i have as options, one of the following: Sony Xperia Z1 Compact, Sony Xperia Z, ASUS ZenFone 2 (the 5" screen one), Sony M4 Aqua, Motorola Moto G 3rd Generation, Nokia Lumia 925 and Nokia Lumia 830. Considering only the camera quality and discounting any preference for one or another O.S., and also considering the improvements of the camera quality that have been made on some of these smartphones up to now, Which one of these do you think that would fit best my expectations? Greetings
    PD: Sorry in advance for any gramatical error since i´m not a native speaker of English.
    08-22-2015 06:56 PM
  2. Raptor007's Avatar
    I can say Nokia has done great things with their cameras, and I do have a ZF2 which is listed in your choices, but I would not recommend that if you want a top performing camera in your phone. Its ok, does the job and its an all around great phone just not a top camera.
    If the camera is a key feature check out Samsung S6, Note 5 or the LG G4.
    sebadnox likes this.
    08-22-2015 08:24 PM
  3. sebadnox's Avatar
    I want a good preformer, but on the range of prices that i´m looking for, and by here these last phones that you´ve named, overpases widely the amount of money that i´ve destined to buy a smartphone. That´s why i´m asking between these phones or others with good camera for the same price range. Greetings.
    08-22-2015 10:23 PM
  1. Trying to install cyanogen mod 12.1 on sprints note 3
    By 50chipz in forum Legacy Android & Other OS's
    Last Post: 08-26-2015, 11:22 AM
  2. Have you disabled any apps or services for better battery life?
    By smooth4lyfe in forum Samsung Galaxy Note 5
    Last Post: 08-23-2015, 11:10 AM
  3. Replies: 1
    Last Post: 08-22-2015, 09:49 PM
  4. Missing Features and Graphic Glitches after Upgrade to 5.0.1
    By gogent in forum Samsung Galaxy Note 4
    Last Post: 08-22-2015, 06:38 PM
  5. From the iPhone 6+ to the Note 5- A Day in Review
    By SCD23x in forum Samsung Galaxy Note 5
    Last Post: 08-22-2015, 06:31 PM
