1. Shyatic's Avatar
    Hey all,
    I cracked my Samsung S4 (LCD and all), and need a replacement that's pretty cheap. I don't care about the camera, not much about the battery life, but care about performance (it's basically a work phone and I use our email app -- which is a beastly app -- pretty regularly), and a decent screen.
    I don't even care about the weight or call quality much, since it's used for a primary work focus. I guess call quality would be a distant third requirement. And the ability to have a case is important -- don't want a repeat of what happened to my S4
    08-24-2015 03:32 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! 2nd gen Moto E is worth looking at: http://www.amazon.com/Motorola-Moto-...cUvbUpU4633029. $90 on Amazon.
    08-24-2015 07:10 PM
  3. Rukbat's Avatar
    If you want to save money, consider used - after all, your S4 wasn't new). Look on Swappa.
    Or get an estimate on repairing the S4, if the screen is the only thing wrong. (It's possible that only the digitizer is actually broken, which would make the repair even cheaper.)
    B. Diddy likes this.
    08-24-2015 07:48 PM
  1. Replies: 1
    Last Post: 08-24-2015, 07:15 PM
  2. Note 4: my phone is locked, how can I get it unlocked?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 08-24-2015, 05:02 PM
  3. Note 4: my phone is locked
    Last Post: 08-24-2015, 03:26 PM
  4. Replies: 1
    Last Post: 08-24-2015, 03:25 PM
  5. Why don't my phone call details no longer show?
    Last Post: 08-24-2015, 03:05 PM
