A AC Question Aug 25, 2015 #1 How do I display time and weather I think I accidentally removed the weather and time display on the screen
worldspy99 Well-known member Oct 15, 2013 1,952 0 0 Visit site Aug 25, 2015 #2 Re: How do I display time and weather What phone are you using? You need to go to widgets and select the time/weather widget in the size you had before you accidentally deleted it. Good luck.
