1. jeffery soloc's Avatar
    i cracked my screen on the inside but the glass is not broken the touch screen still works in some places on it is there any way it can be fixed without buying a new one ???? my phone is on i can see some light and i can feel the vibration from me touching the screen but i can not see anything on it
    08-26-2015 01:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does the screen turn on, or does it stay off but still register touch? Screens can be replaced, so you don't necessarily have to buy a new phone. I'd recommend having a qualified technician replace the screen rather than do it yourself, though, unless you have experience with it.
    08-26-2015 02:06 AM
  3. jeffery soloc's Avatar
    the screen turns on and it does register to touch but only in certain areas
    08-26-2015 02:38 AM
  4. B. Diddy's Avatar
    Yeah, you'll need to the get the screen and digitizer replaced. Take it to a local repair shop, or contact a Samsung service center (although the latter will probably be more expensive).
    08-26-2015 02:45 AM
  1. Tempered Glass Screen Protector for front and back?
    By Rahim Esmail in forum Samsung Galaxy Note 5
    Last Post: 08-07-2016, 06:08 PM
  2. Why don't I have a software update option on my device?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-20-2016, 02:34 PM
  3. Replies: 1
    Last Post: 09-06-2015, 01:27 AM
  4. Came to the note 5 from the G4
    By StevenJ_AK in forum Samsung Galaxy Note 5
    Last Post: 08-26-2015, 07:15 AM
  5. On my android 4G my emotions changed to 1 smily face
    Last Post: 08-26-2015, 02:14 AM
