1. AC Question's Avatar
    I have two unbranded android tablets which I bought off eBay about six months ago.
    Both tablets have the same problem. One day the wifi was not connected. When I click on wifi connections there are no networks showing and it will not search for them. The on off switch button for wifi on screen is always off. When I try to switch it on it will go to the on position. But it will be blacked out. And if I come out of wifi setting and then back on to it again it will be off.
    I have manually reset it. Factory restored it. Turned mobile data (which I don't have) off. I am all out of ideas.
    Any advice?
    08-26-2015 05:37 AM
  2. Rukbat's Avatar
    You aren't going to get much help with unbranded devices, because almost nothing is known about them. Normally I'd suggest backing everything up, then reflashing the ROM - but you can't flash the ROM because you don't know where to get it. (And bringing a device like that to a shop will usually cost more than you paid for it.)
    08-27-2015 02:42 AM
  1. How do I connect a Bluetooth for Audio listening?
    By sakre in forum General Help and How To
    Last Post: 08-27-2015, 02:45 AM
  2. Replies: 1
    Last Post: 08-26-2015, 05:14 AM
  3. My Samsung Galaxy Tab 10.1 keeps restarting?
    Last Post: 08-26-2015, 04:59 AM
