1. KoRnTx512's Avatar
    I have an LG Sunset (LTE, Android 5.0) and my carrier is Straight Talk. I am wondering if my phone would be compatible with a MHL adapter and what not so I could possibly connect and view my phone's contents on my HDTV.
    08-26-2015 03:01 PM
  2. Rukbat's Avatar
    LG doesn't list MHL in the specs, and the phone isn't compatible with Chromecast, so about the best you can do would probably be to run Chromecast supported apps and use the Chromecast device on your TV. (You'll need working wifi - you don't need an internet connection, except to initially set the Chromecast device up, but that can be done on any TV on any Wifi - for Chromecast to work, because that's how the phone connects to it, but even a cheap wifi router will work)
    08-26-2015 03:42 PM
  1. Replies: 1
    Last Post: 08-27-2015, 01:42 AM
  2. Which screen protector should I get for my Galaxy S6?
    By kslim619 in forum General Help and How To
    Last Post: 08-26-2015, 09:55 PM
  3. Replies: 1
    Last Post: 08-26-2015, 09:49 PM
  4. Can I get some help with contacts?
    By pdxrealtor in forum General Help and How To
    Last Post: 08-26-2015, 05:21 PM
  5. Replies: 0
    Last Post: 08-26-2015, 02:36 PM
