1. William Dennis's Avatar
    Hello,
    Doing a refurbish on a Samsung Note 10.1 (GT-N8000). Tablet is not powering on. After opening the tablet I inspected all ribon cables and connectors, all look in good condition. I continue measuring the battery voltage. The Notes two red cables are reading about 3.5v - 3.8v. The blue which I assume is the charging lead is flat 0v. I check the 30pin charging port and looks like there may be a degree of corrosion.
    The tablet was missing its 30pin charging cable. I had to order a replacement cable. I have nothing else to test the charging cable with. So, its quality is unknown.
    Opinions please:
    Does this sound like a charging port issue? The under side of the charging cable looks like there may be an imperfect as well.
    Could this be a battery issue instead? I would think if that was the case the tablet would at least try to power up.
    Thanks
    08-28-2015 08:24 AM
  1. Why does my Samsung S4 keep turning off?
    Last Post: 10-26-2015, 07:39 PM
  2. Samsung Galaxy S6 Battery problem
    By mogman80 in forum Samsung Galaxy S6
    Last Post: 09-01-2015, 08:37 AM
  3. Why won't an app download on my Samsung phone?
    By AC Question in forum Samsung Android Phones
    Last Post: 08-28-2015, 07:26 AM
  4. Samsung Galaxy S5 Timeline
    By simon evans3 in forum Samsung Galaxy S5
    Last Post: 08-28-2015, 07:21 AM
  5. Replies: 0
    Last Post: 08-28-2015, 06:37 AM
