Disk accessible from PC in Recovery Mode but having problems writing, what should I do?
A
AC Question
Disk accessable from PC in Recovery Mode but having problems writing
Hello!
I've tried quite a lot to recover my Meizu MX2. It got stuck in a boot loop.
Anyway:
In order to flash a new firmware onto my system I am trying to copy a "update.bin" file to my root folder on the device. This seems to work (processbar, realistic time needed, file seen shortly after on device).
As soon as I refresh or restart the device in order to use the copied file as desired; It is not on the disk anymore. Like it has been forgotten..
I have tried to copy/write other files to the disk as well. Same problem.
Your help is much appreciated! Since my device is unusable without a solution.
Best regards and thanks in advance!
samyblaze
