1. AC Question's Avatar
    I am using Gionee Pioneer P6 and recently a problem occurs that when I use camera ( front or rear), it shows blurr and event touch control not works. but when I clear the camera data it works fine for one shot only. Another wonder thing is camera works fine in whatsapp cam! I totally confussed about my mob's problem. Can anyone here find a solution for mobile?
    08-28-2015 12:18 PM
  2. belodion's Avatar
    Try Safe Mode....a third-party app may be causing trouble.
    08-28-2015 01:10 PM
  3. Rukbat's Avatar
    If that doesn't fix it, try Camera FV-5 Lite. It's a better camera app than the ones that come with the phone anyway. (The only reason to keep using the stock camera app is if you only take snapshots. If you want to take pictures, you need an app like FV-5, and even the free version is miles ahead of any stock app.) (I'll be trying to get a picture of Saturn through a small telescope tonight, and it might take a bit of a long exposure - FV-5 can do it.)
    08-28-2015 06:11 PM
  1. How do I get music from my sd card onto my music app?
    Last Post: 09-28-2015, 10:29 AM
  2. Replies: 1
    Last Post: 08-28-2015, 06:31 PM
  3. Why has the flashing on my Samsung GT-S5282 again and again failed?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 08-28-2015, 06:29 PM
  4. My Wifi is stuck off, can anyone help?
    Last Post: 08-28-2015, 12:06 PM
  5. Why does my Samsung Android S Tab4 drop wifi, but says its connected?
    By AC Question in forum Samsung Galaxy Tab4 7.0
    Last Post: 08-28-2015, 12:04 PM
