Upgrade to 5G: Save $50 on the unlocked Pixel 4a today
Restore New Phone (Atrix) w/ Old Phone Settings (Atrix)
- I currently have the N1 and hope to be up?/down?/sideways?-grading to the Moto Atrix.
My question for y'all is this. Can I use Astro or Titanium to backup the N1 (ringtones, remembered wifi, apps, email accounts, general setting, etc) and restore them on the Atrix? If not, does anyone have any other recommendations?
And while I'm at it, how upset am I going to be going from stock froyo to blur?
Thanks in advance01-31-2011 03:52 PMLike 0 - You should be able to back up your apps using astro but you would need root access to us titanium backup. And after you reinstall them it won't restore application data just the app your better off using the market to download them IMO. You will not be able to transfer over your system setting unless there is an app that I'm not aware of.jess.hickey likes this.01-31-2011 04:12 PMLike 1
Thanks in advance01-31-2011 05:35 PMLike 0
- Forum
- Android Central Community
- General Help and How To
