A
AC Question
how do i fix my phone if it turns on 7 off repeatedly when i try to power on
I cant even make it to the home screen. If i put it on the charger it may stay on for a little while but never longer than 5 minutes. It charges & holds charge. i have wiped the cache clean & even restored factory settings which worked for 10 minutes but then started doing the same thing again.
