1. AC Question's Avatar
    I cant even make it to the home screen. If i put it on the charger it may stay on for a little while but never longer than 5 minutes. It charges & holds charge. i have wiped the cache clean & even restored factory settings which worked for 10 minutes but then started doing the same thing again.
    08-29-2015 09:11 PM
  2. Rukbat's Avatar
    The first hour of charging a completely dead battery (which you should never do) doesn't put much charge into it. Leave it turned off and charge it overnight, at least, then see what happens.
    08-29-2015 09:44 PM
  1. Horrible phone call sound quality just popped started
    By FormerTexan in forum Samsung Galaxy S6 active
    Last Post: 09-23-2015, 01:55 PM
  2. Is there a way to change the date on a photo in Gallery?
    Last Post: 08-29-2015, 09:45 PM
  3. Replies: 1
  4. Replies: 0
    Last Post: 08-29-2015, 08:52 PM
  5. Duplicated synchronization of Contacts - how to stop?
    Last Post: 08-29-2015, 08:35 PM
