1. AC Question's Avatar
    So I have been using Go SMS Pro for a while now, and decided to finally put its "private box" to use. I tried to move my boyfriend and I's conversation into the "private box" but it would not show up, so I tried to do it about 4 more times, and when I checked, I noticed that our conversations have been copied 4 times. (So for each text, there are 4 other copies) I was just wondering if anyone knows how to alter that without deleting all of our conversations. I just want to get rid of the other 4 copies per text.
    I hope I explained it alright.
    08-31-2015 12:13 AM
  1. How do I turn the wifi on?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 08-31-2015, 12:54 AM
  2. Does the battery last longer if the wifi is on?
    Last Post: 08-31-2015, 12:52 AM
  3. How much will the Note 5 cost?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 08-31-2015, 12:21 AM
  4. Can I get the Note 5 in India?
    Last Post: 08-30-2015, 11:18 PM
  5. Why am I unable to format and flash the stock rom with odin?
    Last Post: 08-30-2015, 11:12 PM
