1. AC Question's Avatar
    Hey, I got to the reboot menu on my tablet but now I can't select anything and can't choose the right option. I need to get it back to it's factory settings.
    09-01-2015 12:19 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which tablet?
    09-01-2015 01:49 AM
  3. Mortalia Dragulis's Avatar
    I'm not sure wich tablet on the back it says mobile internet device with android OS problem is I havent used it for a while and I cant get to the settings to wich one it is . It could possibly be a tablet from an other manufacturer with an android system.
    09-01-2015 01:09 PM
  4. B. Diddy's Avatar
    It sounds like a no-name direct-from-China tablet. Those are always more prone to hardware or firmware defects, and can be difficult to troubleshoot.
    Can you show us a screenshot of the menu you see? http://forums.androidcentral.com/amb...d-central.html
    09-01-2015 04:36 PM
  5. Mortalia Dragulis's Avatar
    How do I reboot my Android tablet?-tphoto_00014.jpg, couldn't take a screenshot.
    Now the only problem is from here on out it doesn't work anymore i installed Minimal ADB and Fastboot setup.exe but can't figure out what else to do.
    09-02-2015 08:49 AM
  6. B. Diddy's Avatar
    Congratulations on getting to that menu! It's not always easy to figure out. But the highlight bar doesn't move if you press the Volume Up/Down buttons?
    09-02-2015 11:48 AM
  7. Mortalia Dragulis's Avatar
    it doesn't it only reacts to the home button, making the menu appear and disappear.
    09-02-2015 03:39 PM
  8. B. Diddy's Avatar
    Was the tablet malfunctioning before you tried all of this? It may be that there's a hardware defect that is affecting the Volume buttons.
    09-02-2015 06:21 PM
  9. Mortalia Dragulis's Avatar
    no, not that i can remember at least it alays worked really well
    09-03-2015 11:45 AM
  10. B. Diddy's Avatar
    You could try connecting a USB keyboard (which would require a USB-to-microUSB adapter), but I'm not sure that'd work in the Recovery Menu.
    09-03-2015 12:02 PM
  11. Mortalia Dragulis's Avatar
    tried connecting to my computer but that didn't work out to well
    09-03-2015 03:36 PM
  12. B. Diddy's Avatar
    I meant a standalone USB keyboard, not your computer.
    09-03-2015 03:44 PM
  1. Replies: 2
    Last Post: 09-02-2015, 01:49 PM
  2. My phone won't tell me when its dying.. what to do?
    Last Post: 09-01-2015, 02:26 PM
  3. Connect Note 5 to samsung gear s
    By Hend Mora in forum Samsung Galaxy Note 5
    Last Post: 09-01-2015, 12:35 PM
  4. How to bypass start up wizard on my Moto E?
    By AC Question in forum Moto E
    Last Post: 09-01-2015, 01:50 AM
  5. Replies: 0
    Last Post: 08-31-2015, 11:46 PM
