1. AC Question's Avatar
    On Android 4.4 in the settings>wireless & networks>WiFi NETWORKS is full of different signal from different areas, how do I erase/delete/get rid of all these signals not being used ?
    09-01-2015 01:46 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are they all saved networks, or are they just networks that are present around you at that time, while your wi-fi radio is on? You can't get rid of the active networks that the wi-fi detects around it, even if you never log into them.
    If you want to get rid of saved networks, go to Settings>Wi-fi, tap Menu>Saved Networks, select the network, and tap Forget.
    09-01-2015 07:52 PM
  1. How much luck has everyone had going naked?
    By pantlesspenguin in forum LG G4
    Last Post: 09-23-2015, 11:46 AM
  2. Replies: 2
    Last Post: 09-05-2015, 04:33 AM
  3. Replies: 1
    Last Post: 09-01-2015, 07:56 PM
  4. How to clone a smartphone ?
    By rssethi_6 in forum Moto X (2014)
    Last Post: 09-01-2015, 01:53 PM
  5. Replies: 0
    Last Post: 09-01-2015, 01:38 PM
