1. AC Question's Avatar
    I have searched the web but it seems like im the only one with this issue. My phone can only use 4g signals which is LTE/WCDMA/GSM I have asked the store I bought it from but they havent heard of this before. My phone wont switch over to 3g or 2g. Its either 4g/lte or nothing with my phone. Its a Samsung Galaxy Light, maybe I got a bad phone idk. A factory reset didnt work so Im at a loss or im missing something. I may need to buy another phone if this is unfixable.
    Also you may wonder why i want lower network speeds. simple I live in a **** area that I get signal on rare occasions.
    09-02-2015 09:55 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! One workaround is to go to Settings>Connections>More Networks>Mobile Networks>Network Mode, and select WCDMA/GSM (Auto Connect), which forces 2G/3G only. Of course, you won't be able to connect to LTE at all with this setting.
    Also, which carrier are you on? Check to make sure your APN settings are correct--you can usually find them on the web by searching for "[your carrier] APN settings."
    09-02-2015 10:56 PM
  3. Filthy Perfection's Avatar
    I have tried that but with no luck. My carrier is Metro PCS
    09-03-2015 12:24 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Tried what? Checking the APN, or changing to WCDMA/GSM?
    09-03-2015 12:21 PM
  1. Thoughts on NFC?
    By Haven King in forum General News & Discussion
    Last Post: 09-07-2015, 03:36 AM
  2. Replies: 1
    Last Post: 09-02-2015, 11:18 PM
  3. How can I synchronizing my Phonebook with my car?
    Last Post: 09-02-2015, 11:15 PM
  4. May i use the Samsumg note 3 in metro PCS ????
    Last Post: 09-02-2015, 11:08 PM
  5. How do you fix your phone when it randomly come on and off?
    Last Post: 09-02-2015, 10:57 PM
