1. AC Question's Avatar
    i have xolo q 800.. in that, camera is working only when switch on.. after few minutes it's not working.
    09-03-2015 01:28 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    09-03-2015 07:00 PM
  1. S Pen air command not opening
    By Marcx662 in forum Samsung Galaxy Note 5
    Last Post: 01-29-2016, 11:34 AM
  2. Here it is ... the Gear S2
    By castone001 in forum Samsung Gear S
    Last Post: 09-13-2015, 01:09 PM
  3. Why does the new update not let me connect to Wi-Fi anymore?
    Last Post: 09-03-2015, 07:16 PM
  4. Replies: 0
    Last Post: 09-03-2015, 12:55 PM
  5. My new note edge screen just dims out randomly.
    By Nandini in forum Ask a Question
    Last Post: 09-03-2015, 12:52 PM
