1. valantakos's Avatar
    hello i have the device : MXIII M82 Quad Core KitKat Cortex A9 ARM Mali - 450 4K Android 4.4 5GHz WiFi Bluetooth TV Box 2GB DDR3 RAM 8GB ROM Support Max 32GB Capacity - from gearbest.. all was fine.. because i tried to install a app that doesnt allow root devices i tried to un-root..
    with hide my root and xposed something like that and now when i tried to run supersu or other app that uses root access cant load ... in supersu when it starts it says " su binary not found "
    i tried with kingroot to do root again but nothingit failed .. can someone help me?
    09-04-2015 09:48 AM
  2. srkmagnus's Avatar
    Welcome to the forums!
    You don't have root. Try looking for another root method for your device and give that a try. Be sure to know the process well and have the information you need to fix any problems which come up.
    Golfdriver97 likes this.
    09-04-2015 10:13 AM
  3. valantakos's Avatar
    hi.. thanks for the reply.. i see i tried with other options but still cant root.. the device have amlogic-s802 cpu can you help me with any guide that i can do the root? because all guides is for phones but i want to root the tv box and i cant find anything.. :/
    09-04-2015 10:30 AM
  4. Golfdriver97's Avatar
    I'm a little confused. You are rooted, or not?
    09-04-2015 11:45 AM
  5. valantakos's Avatar
    it was when i buy it.. but after i install hide my root or xpsed , rootcloak and tried to temporary disable the root i had problem when i tried to get back the root.. and now on supersu it says no su binary found.. :/
    09-04-2015 12:10 PM
  6. Golfdriver97's Avatar
    Superuser might need to be updated
    From my G4
    Android Central Ambassador Team Leader
    09-05-2015 11:49 AM
  1. Replies: 5
    Last Post: 09-08-2015, 11:15 PM
  2. Replies: 1
    Last Post: 09-06-2015, 03:20 PM
  3. Why isn't my S6 ringing or vibrating when I get messages?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 09-04-2015, 12:36 PM
  4. Why aren't Apps showing in the Play Store?
    By AC Question in forum Google Play Store
    Last Post: 09-04-2015, 12:17 PM
  5. Replies: 0
    Last Post: 09-04-2015, 07:24 AM
