1. AC Question's Avatar
    why is Exchange Service killing my battery it uses 53% of my power supply
    09-04-2015 09:43 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Do you actually use an Exchange email? If not, disable Exchange Services in the Settings>Apps>All​ menu.
    09-04-2015 10:07 PM
  3. Rukbat's Avatar
    Even if you use it, it' using 53% of the amount of power being used, not 53% of the battery capacity. That could be 53% of 2% of the battery capacity.
    If you're using it, and have an app checking Exchange mail every 5 minutes, it's going to use a lot of battery. If you have to get mail immediately, and you can't convince the administrator to set up an IMAP account for you, you'll have to put up with it.
    09-04-2015 11:35 PM
  1. Question to Edge Plus users - How does it feel in the hand?
    By VJKotts in forum Samsung Galaxy S6 edge+
    Last Post: 09-11-2015, 06:50 AM
  2. Tracking battery life
    By Mike Jochim in forum LG G4
    Last Post: 09-05-2015, 06:19 PM
  3. Replies: 1
    Last Post: 09-04-2015, 10:15 PM
  4. Replies: 1
    Last Post: 09-04-2015, 09:31 PM
  5. I cannot access the DND (do not disturb) menu anymore. Why?
    Last Post: 09-04-2015, 09:30 PM
