1. Muhammad Asam's Avatar
    I have Samsung Alpha which i bought 2 months back. I am using finger scanner for lock screen and private mode access. But all of a sudden the finger scanner is not working at all. There is some weird bug i cannot even change the screen lock from fingerprints to swipe, pattern or none. when i go to the settings to change the lock screen that setting page doesn't work.
    Now i have some important files stored in private which i cannot access. I want to do factory reset but i am not sure if the backup will back the private files too and i will be able to access after that? what should i do to access the private files and to save them.?
    Regards
    09-05-2015 11:17 AM
  2. belodion's Avatar
    Can you try Safe Mode?
    09-06-2015 06:11 PM
  3. Muhammad Asam's Avatar
    What to do in safe mode? I tried going there and wipe the cache. But nothing happened. I just want my private files to be saved if i am going to reset the factory. Let me know how can i backup the private files. I can't turn private mode on because of finger scanning bug.
    09-08-2015 03:40 AM
  1. Why is my location incorrect, even when location service is on?
    Last Post: 09-06-2015, 06:14 PM
  2. Replies: 1
    Last Post: 09-05-2015, 03:43 PM
  3. Replies: 0
    Last Post: 09-05-2015, 11:09 AM
  4. Replies: 0
    Last Post: 09-05-2015, 11:08 AM
  5. Why is my Samsung galaxy s4 unresponsive?
    Last Post: 09-05-2015, 10:48 AM
