1. AC Question's Avatar
    just want it of my screen
    09-05-2015 03:13 PM
  2. anon(5600632)'s Avatar
    Whether you can uninstall it depends on your phone & carrier and whether it is "original equipment".. But you should be able to press and hold it, then drag it to "remove" or a trash can. This'll remove it from your home screen but not delete the app. Go to Settings-Apps and find it - this is where you may be able to uninstall or disable.
    09-05-2015 04:04 PM
  1. How to change my messaging theme or text bubbles?
    Last Post: 11-30-2016, 05:59 PM
  2. Quality of photos in Cloud Storage?
    By Arlizz in forum General Help and How To
    Last Post: 09-06-2015, 12:38 AM
  3. What do the red x's square under battery mean?
    By AC Question in forum Batteries
    Last Post: 09-05-2015, 02:21 PM
  4. How to clear note 5 search history?
    Last Post: 09-05-2015, 02:17 PM
  5. How to put back DefaultContainerService.apk?
    Last Post: 09-05-2015, 02:15 PM
