Why isn't my volume sounding for text or alarms?
A
AC Question
My volume isnt sounding for text or alarms
I didnt turn off volumes are on but no sound when receive message or when alarm is to sound
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: My volume isnt sounding for text or alarms
Go into system settings - sounds. Make sure the volumes are set to the appropriate levels. Also, be sure to check the alarm and messaging apps and check the volume settings within those.
kerokekerol
