1. hankspurs's Avatar
    I got a new phone,my old phone had a 1gig micro card with data on it, im putting a 64 gig card in my new phone,im not sure how to transfer the info from the 1gig onto the 64 gig without losing it. thanks
    09-05-2015 06:46 PM
  2. srkmagnus's Avatar
    You can transfer all the data of the 1gb card to the internal memory of the phone, then insert the 64gb card and transfer from the phone to the new card. Otherwise, you can use a computer and do the same, provided you have a card reader.
    09-05-2015 07:06 PM
  1. How to clear phone's cache
    By kidzfun in forum LG Leon
    Last Post: 11-04-2015, 08:56 PM
  2. Just picked up wireless charging back for S5, need case to fit. Suggestions?
    By LinuxConvert in forum Samsung Galaxy S5 Accessories
    Last Post: 09-20-2015, 08:49 PM
  3. Replies: 1
    Last Post: 09-05-2015, 06:40 PM
  4. Whatever happened to some Facebook apps?
    By lascott7 in forum Android Apps
    Last Post: 09-05-2015, 05:56 PM
  5. Any way to permanently load watchmaker faces to GWR?
    Last Post: 09-05-2015, 05:55 PM
