1. AC Question's Avatar
    My phone and I go near water everyday and there are some CLOSE calls. I need to know. Its a Kyocera hydro life android 4.3
    09-05-2015 08:02 PM
  2. ab304945's Avatar
    IP57 certified - dust and water resistant
    - Water resistant up to 1 meter and 30 minutes
    09-05-2015 08:20 PM
  3. italygrl1's Avatar
    Phones are water resistant since they are electronic devices. Submerging in water would fry the inner working so try to be careful.
    09-05-2015 10:19 PM
  4. Rukbat's Avatar
    The last warterproof phone (meaning guaranteed if it got damaged by water) was the nextel i700.
    Put your phone into a ziplock baggie and zip it shut. Insert that, zip end first, into another baggie. Zip that one shut. (Test the bags without a phone first - some brands leak.) Now you can toss any phone into the water. (Hose the baggie off first, then let it dry, before opening anything.)
    If you fasten (no holes, please) a large key float to the baggies, even if you drop your phone over the side of a boat in a deep lake, all you have to do is reach out with a net and get it back - it won't sink. (You should see the jaws drop when you nonchalantly ask "Does anyone have a net, I dropped my phone in the water", then bring it back and finish the call you were on. You'll be able to sell the bags for $5 a pair.)
    09-05-2015 10:27 PM
  1. How can I connect my S6 Edge+ to my Bluetooth headset?
    Last Post: 09-05-2015, 10:32 PM
  2. Replies: 1
    Last Post: 09-05-2015, 10:30 PM
  3. What is the best music app for the S6 Edge+?
    Last Post: 09-05-2015, 10:26 PM
  4. How can I get Clash of Clans onto my S6 Edge+?
    Last Post: 09-05-2015, 10:24 PM
  5. How do I move icons on my phone from one screen to another?
    Last Post: 09-05-2015, 10:22 PM
