1. Uzziel Roge Adurante's Avatar
    Sometimes my tablet will charge but sometimes it will not . I thought that the problem is on the charger but the charger is perfectly fine, it works on other phones but not on my tablet . Is it the charging receptical that is damaged? How can i fix it without replacing it? Pls help me guys
    09-05-2015 09:04 PM
  2. Rukbat's Avatar
    If moving the cable where it enters the tablet makes it charge, the charging port in the tablet is loose inside. It has to go to a repair shop.
    09-05-2015 11:22 PM
  3. italygrl1's Avatar
    Try it in a different outlet. If its still not working then you need to contact Samsung and see what options they have. If you are within a year they have a manufacturer warranty that will cover the repair.
    09-05-2015 11:25 PM
  1. How can I connect my S6 Edge+ to my Bluetooth headset?
    Last Post: 09-05-2015, 11:32 PM
  2. Replies: 1
    Last Post: 09-05-2015, 11:30 PM
  3. Is my phone waterproof or water resistant?
    Last Post: 09-05-2015, 11:27 PM
  4. How can I get Clash of Clans onto my S6 Edge+?
    Last Post: 09-05-2015, 11:24 PM
  5. How do I move icons on my phone from one screen to another?
    Last Post: 09-05-2015, 11:22 PM
