1. AC Question's Avatar
    When ever a call comes in this pops up "Unfortunately, the process com.android.phone has stopped. How do I fix it?
    09-07-2015 12:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    09-07-2015 02:22 PM
  3. UsmanA's Avatar
    Thank you for the answer. But I have tried all these to no avail. what else can I do
    09-08-2015 05:18 AM
  4. B. Diddy's Avatar
    If it's happening in Safe Mode, then it's either a firmware glitch or a hardware defect. Unfortunately, these kinds of problems are more common with off-brand devices like yours. You could try contacting Tecno's support team: https://www.tecno-mobile.com/en/contact-us
    09-08-2015 08:11 PM
  1. Replies: 4
    Last Post: 11-03-2017, 02:47 AM
  2. Replies: 4
    Last Post: 09-11-2015, 05:49 PM
  3. Replies: 3
    Last Post: 09-10-2015, 08:27 PM
  4. Can a Jawbone Blutooth device talk to my phone if it is in airplane mode?
    Last Post: 09-09-2015, 12:25 PM
  5. Replies: 1
    Last Post: 09-07-2015, 02:39 PM
