1. fooferdoggie's Avatar
    on my iphone my audiobooks I ripped with m4r and when I synced them audible found them and let me play them. but I don't know if or how this will work on my s6. right now the books are on my device in a audiobook folder I made. I have both formats m4r and m4a but no go. do they have to be in the right folder? and if so where or different format? or not at all?
    09-07-2015 01:42 PM
  2. nahoku's Avatar
    According to the S6 manual...
    The S6 supports these audio codecs...
    Audio: MP3, WAV, WMA, eAAC+, FLAC
    If your files don't play, it means they're not supported and you need to convert them to a supported audio format.
    09-07-2015 08:42 PM
  3. fooferdoggie's Avatar
    I can play them using smart audio player without converting them. But I would like to play them through audible and that's what I need to figure out how to do
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    09-07-2015 10:27 PM
  4. nahoku's Avatar
    You need to find out which codecs audible supports and convert the files as needed.
    09-08-2015 03:04 AM
  5. fooferdoggie's Avatar
    thats what I am hoping someone knows. I wish I could just get all my books off of audible but I listen to too many to have to buy them all.
    09-08-2015 10:42 AM
  1. Returning to stock ROM but leaving everything else unlocked
    By koreiryuu in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 09-13-2015, 09:56 AM
  2. IF you considered 6 edge+, why did you decide on the Note 5?
    By metropolitim in forum Samsung Galaxy Note 5
    Last Post: 09-11-2015, 08:11 PM
  3. How do I cancel my Pandora subscription?
    Last Post: 09-09-2015, 11:57 AM
  4. How do I get root access on my Nokia X2 DS?
    By Vadhiya Bhikhan in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-09-2015, 11:53 AM
  5. Does anyone use
    By Kjthomas0724 in forum Samsung Galaxy Note 4
    Last Post: 09-08-2015, 06:59 AM
