1. Jaskaranpreet Singh's Avatar
    I have Micromax A104 (canvas 2 fire). Few days back i got a message while opening the camera "Can't connect to camera". After that the back camera stop working. Then i perform the factory reset from the phone and after reset camera start working. It was working fine until 2 days back and same problem occur. I can do factory reset again and camera may start working but i m tired of it. I want to know if the updates of other apps can cause this problem? Is there any permanent solution to this?
    09-10-2015 02:45 AM
  1. screenshot short cut not working
    By retsoamz in forum Samsung Galaxy A5
    Last Post: 09-10-2015, 06:37 AM
  2. Replies: 0
    Last Post: 09-10-2015, 02:38 AM
  3. Front Camera dose not work ?
    By Mahmoud Rajab in forum Sony Xperia Z2
    Last Post: 09-10-2015, 02:26 AM
  4. Replies: 0
    Last Post: 09-10-2015, 12:42 AM
  5. Replies: 1
    Last Post: 09-10-2015, 12:31 AM
