Hey guys,
I just recently got a V19 "generic" brand phone and ironically, the RAM of the device is indeed 4 GB and displays that way, the Internal and Phone storages both show 16 GB. Now, usually I would actually expect the RAM to have been incorrect, not the internal storage. However, in this case, the Internal storage is ironically unusable after the first 2 GB of it are full. I'm including some screenshots of the device, for you to get the idea. Obviously, some chinese kid played in his garage a bit to make this phone because the serial number is 0123456789ABCDEF - LOL!
Because I've less than 10 posts here hence I can't post links to this thread, the phone specs are:
GPU: Mali-450 MP
CPU: MTK6592 Octa Core 2.0GHz
RAM: 4GB
ROM: 16GB displayed, although listing supposedly advertised 32 GB
5.5 Inch HD IPs display 1920X1080
Question: Is there any way to actually see the available space? Obviously, the chinese fellow has "fooled" the hardware into thinking it's much more. Now, I also think it might have something to do with SuperSU being a "Default" app which cannot be removed. Also, the phone has a launcher so I'd probably have better luck changing the ROM to something else, which would probably give me the correct internal storage while breaking almost everything else down. So is there anything I could do to actually see it or "unlock" the rest of it if something might be blocking it? Would installing another launcher allow me to at least see some of the "built-in" stuff, since Titanium Backup doesn't seem to detect the SuperSU (It shows "Detecting SU and BusyBox", guess if it actually goes beyond that after 10 minutes of waiting?
I wouldn't care much if this turns out to be unfixable or if I have to live on with it, mainly because I got the phone for 100 bucks on AliExpress and because I got plenty of SD cards I don't use so I could plug one in and get my issue resolved very quickly but it bugs me to have this issue hence my question. Any help or hints will be appreciated.
