belodion Co-Ambassador Team Lead Moderator Jun 10, 2014 39,388 254 83 Visit site Sep 13, 2015 #2 Re: mmy phone is locked If you can, remove the battery and replace it. Otherwise, try holding Power for about twenty seconds to simulate a battery pull. Tell us whether that helps. Posted via the Android Central App
