1. AC Question's Avatar
    I have a SanDisk 8 gb class 10 sd card that isn't working properly anymore.
    The card is not detected by my phone and computer if I am connecting it directly or with an adaptor but if I connect it trough a card reader or a less smart phone (not running android) to the computer I can read it and edit the files from it.
    The phone can read other sd cards and I managed to format the sd card but it is still undetected.
    09-13-2015 04:15 AM
  2. miner_films's Avatar
    Since you have other ways of the SD card being read, I highly recommend that you backup whatever you have on that SD card. Then format that SD card and move the files across (that's if it can still be read/detected), but you still want to have a backup of whatever is on the SD card (whatever you do don't delete your backup), if the SD card can not be read/detected still then I would consider swapping it out for an SD card that can be read/detected.
    09-13-2015 04:50 AM
  1. Replies: 1
    Last Post: 09-14-2015, 11:27 AM
  2. Galaxy S6 charger gets really hot.. Normal or not?
    Last Post: 09-13-2015, 01:51 AM
  3. Not able to connect galaxy s6 with wifi modem 450TC1
    Last Post: 09-13-2015, 01:12 AM
  4. Replies: 0
    Last Post: 09-13-2015, 12:28 AM
  5. Google apps and Facebook not working, how can I get them working?
    By AC Question in forum Google Play Store
    Last Post: 09-13-2015, 12:11 AM
