1. jellibeaan's Avatar
    Thanks for viewing my post. I dropped my galaxy s6 edge just a week ago then noticed just now that there's a small black spot on the edge of the screen. It kinda bothers me now that i know it. I had a little research and thought it was a dead or stuck or whatever pixel but it probably isnt because of its size. Also downloaded an app to fix it but sadly didnt do anything. Idk what it is but if it involves something like replacing my lcd i probably cant afford it. Any suggestions on how can i fix this?
    09-14-2015 03:37 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The drop probably caused it. Screen defects like that often start to spread, so you ultimately may have to get the screen replaced. Since it was due to a drop, it won't be covered under warranty--hopefully you got additional insurance on the phone.
    09-14-2015 03:21 PM
  1. Dust in my depth sensor
    By LostFated in forum HTC One M8
    Last Post: 09-15-2015, 10:41 AM
  2. Should I buy a Moto X Pure or Galaxy S6?
    Last Post: 09-15-2015, 03:28 AM
  3. why wont my phone my sim
    Last Post: 09-14-2015, 03:26 PM
  4. Replies: 0
    Last Post: 09-14-2015, 03:36 AM
  5. Smartphone doesnt turn on
    Last Post: 09-14-2015, 02:57 AM
