How do I remove mobile tracker?
  • Start date Start date
A
AC Question
how to remove mobile tracker
How to remove it from all application list
Re: how to remove mobile tracker
Welcome to Android Central! Which phone? Is this a preinstalled app? If so, then you can't remove it unless you root the phone. You could try disabling it by selecting it in Settings>Apps>All, and tapping Disable. This will prevent the system from ever opening it.
Hi ...To remove mobile tracker...Download app remover from the play store...Next when opening app remover and trying to remove wifi (mobile tracker) it will take you to device administrator as mobile tracker is a device administrator on your phone until you turn this off...Next click on wifi name for mobile tracker and send it to app removers bin... Now you are free of mobile tracker...It is a nasty application to remove as it grants itself all permission to your phone...Good luck people ...App remover is a great application and is free from the play store ??????
mmn112233445566111
