1. none_other_than's Avatar
    On my Galaxy S5, when I look at the Usage Manager it says that Phone has used a good amount of battery. This has been happening for about a week, even though I never even called anyone. Is there a reason for this?
    09-15-2015 07:21 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Do you see a separate Cell Standby listed in the battery stats? If not, I wonder if your device is including Cell Standby into the Phone listing. Cell Standby represents the battery used by the cell radio while idling and trying to maintain a connection. If the signal is poor, Cell Standby will use more energy to maintain that signal, so the battery usage percentage will go up.
    09-15-2015 11:37 PM
  1. Why does my phone receive then rejects multimedia SMS?
    Last Post: 09-16-2015, 01:06 AM
  2. Stuck on login/locked screen, what should I do?
    Last Post: 09-15-2015, 11:40 PM
  3. Replies: 1
  4. Using h7 heat rate
    Last Post: 09-15-2015, 11:39 PM
  5. Spotlight search on Droid?
    By TurboCommander in forum Ask a Question
    Last Post: 09-15-2015, 07:49 PM
