1. AC Question's Avatar
    If I answer a incoming it locks up the phone ie. I can't get the call screen off the screen. It prevents me from minimizing or anything.
    09-15-2015 07:42 PM
  2. Javier P's Avatar
    Which phone do you have? Can't you use the recent apps or home buttons after answering a call?
    09-15-2015 07:55 PM
  1. Why does my phone receive then rejects multimedia SMS?
    Last Post: 09-16-2015, 01:06 AM
  2. Using h7 heat rate
    Last Post: 09-15-2015, 11:39 PM
  3. Why does the phone app use battery on my phone even when I don't use it?
    By none_other_than in forum General Help and How To
    Last Post: 09-15-2015, 11:37 PM
  4. I have a 32gb sd card that my phone is rejecting, what should I do?
    Last Post: 09-15-2015, 08:14 PM
  5. Replies: 0
    Last Post: 09-15-2015, 07:23 PM
