A
AC Question
Can't connect to Miracast using my PC
Hello, i just upgraded to Windows 10 so i can connect to Miracast on my LG Smart TV.
Whenever i try to connect my tv, it's either my wifi disconnected or my monitor sleeps then turns on again.
I checked if my PC supports Miracast & it says it's available, I know the problem is with my computer because i can connect my android phone to the tv, although i tried everything yet i can't seem to find the problem. help?
